S sphinhex Jun 26, 2018 5 0 10 Jun 26, 2018 #1 i want to put an micro atx board in an nzxt h700i?the case supports it so can i?and will there be any disadvantages?Thanks
Solution DRagor Jun 26, 2018 Yes you can. Disadvantages - none that would be caused by installing small board in big case.
DRagor Polypheme Jan 23, 2017 9,097 813 65,440 Jun 26, 2018 Solution #2 Yes you can. Disadvantages - none that would be caused by installing small board in big case. Upvote 0 Downvote Solution
DRagor Polypheme Jan 23, 2017 9,097 813 65,440 Jun 26, 2018 #4 sphinhex : so i can go ahead and buy it? Sure. Just make sure your GPU fits (although not too many GPUs are longer then 16 inches). Upvote 0 Downvote
