smoats Honorable Apr 25, 2012 131 0 10,690 May 17, 2014 #1 Just as the title says. I'm trying to get my grandmothers pc Wifi ready and we've had issues with constant disconnects with usb receivers so I figured I'd ask about the compatibility between the two PCI-e types.
Spectre694 Dignified Feb 28, 2014 2,907 0 13,960 May 17, 2014 #2 Yes you can. You can always install into a larger PCI-e slot but never a smaller one. Upvote 0 Downvote
k1114 Titan May 2, 2010 14,236 93 75,540 May 17, 2014 #3 Actually there are open ended pcie slots that will work with any pcie size in them. Upvote 0 Downvote
smoats Honorable Apr 25, 2012 131 0 10,690 May 17, 2014 Solution #4 Thanks for the info guys! Upvote 0 Downvote Solution
