L lillypat Distinguished Feb 9, 2012 2 0 18,510 Feb 9, 2012 #1 Hello,tripped on my power cord again replaced the port 2x's very expensive having trouble powering p I thought maybe I could jus eave it on
Solution ksiemb Feb 9, 2012 lillypat : Hello,tripped on my power cord again replaced the port 2x's very expensive having trouble powering p I thought maybe I could jus eave it on are you getting power via adapter, and not running just on battery ? Either way, set your power options to turn off monitor & HD after a period of inactivity, will help.
ksiemb Illustrious Nov 15, 2009 12,270 0 41,960 Feb 9, 2012 Solution #2 lillypat : Hello,tripped on my power cord again replaced the port 2x's very expensive having trouble powering p I thought maybe I could jus eave it on are you getting power via adapter, and not running just on battery ? Either way, set your power options to turn off monitor & HD after a period of inactivity, will help. Upvote 0 Downvote Solution
L lillypat Distinguished Feb 9, 2012 2 0 18,510 Feb 16, 2012 #3 Best answer selected by lillypat. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,812 1,861 159,590 Feb 16, 2012 #4 This topic has been closed by Area51reopened Upvote 0 Downvote
