Can I mount a 200mm fan
Codee_frs
Commendable
Aug 23, 2016
I accidently bought a 200mm fan when buying all of the parts for my gaming pc. The case I bought was a Corsair 100r mid-tower and I wanted to know if it was possible to still mount the 200mm fan. Also, how beneficial would it be as Im currently only using the 1 120mm fan that comes with the case.
Judging by the specifications of this case - 100r - it seems the max fan size is only 120mm, this is for the; Front Fans, Top Fans and Rear Fans but this case can fit a 150mm Fan for the CPU cooler.
Hope this helps bud.
