Question Can I not get a flow-through GPU if I have another card installed directly behind my GPU?
Cyber_Akuma
509
21
18,985
Do flow-through GPUs rely on having empty space behind the card to cool properly? I have another card that is directly behind my current GPU, but I want to upgrade. Issue is the potential cards I would want to upgrade to seem to use a flow-through design, which I am worried the other card will block. Does that mean that I can't use these GPUs in my setup?
Short answer, no, you can use any card.
Will the card run hotter and throttle sooner? Likely.
Keep in mind, until a few years ago most cards didn't have flow through designs at all. Some were lower power, some were still quite high power by today's standards.
A lot depends on the airflow in your chassis, how much power the card consumes, etc. Hard to give a definitive answer with minimal information.
Reactions: Roland Of Gilead
My case is a Cooler Master HAF X. It has a 230mm front fan, two 200mm top exhaust fans, a 140mm rear fan, and a 200mm side fan.
Here is an older picture showing the 2080 with the other card behind it: View: https://i.imgur.com/I8uYMaJ.jpg
I wanted to eventually upgrade to a 5070 Ti, preferably a two-slot card as I have other components in my system and don't want a single GPU to basically cover the entirety of my motherboard's other ports. Was considering the Asus Prime 5070 Ti since it's like a 2.25 slot card (Personally, I find it annoying that Nvidia managed to make the 5090 of all things a two-slot design, yet most third party 5070 Tis are 3+ slots... can we please move away from 3-4 slot GPUs being considered the norm?) but that card uses flow-through cooling IIRC. Not sure if it would not run hot in my setup.
That card isn't that long, most flow through designs are only at the rear of the card. Where the GPU actually is is not a flow through so I wouldn't think there would be much difference.
Only exception would be the new FE 5090 I think.
Reactions: Cyber_Akuma
Yes, the card is pretty short, it's a sound card. Didn't consider that the exhaust would be from the back, the card should clear it by a significant margin then.
The 5090 FE is the only one with the PCB in the middle? I thought all the 5000 series FE cards were like that, but I thought the 5000 FE cards weren't flow-through?
Yep, you are right, the 5080 Founder's also has the PCB in the middle. Hadn't actually seen a teardown of that yet. Not that interested in them myself, as it complicates water cooling.
I don't think anyone else followed suite though, so they'll just have the rear half of the heatsink with pass through.
