i have a c2q q9400 and a asrock g41c-gs motherboard and i want to get higher overclock on my chip my motherboard alows me to overclock to 2.75ghz max and will the tape method work shown in this video https://www.youtube.com/watch?v=5rsFVg3s3G0
Doubtful. The Dell system in that video has 0 ability to OC, there's no physical multiplier to change by jumper pins, or bios multiplier able to be user set. The electrical tape just bypasses certain bios restrictions and sets the cpu multiplier higher. With your board, OC is an option, so the bios won't include bypasses as it's already open. You could always try it, but Dell OEM bios is custom written for Dell, so is somewhat different to aftermarket bios setups.
Not for that CPU. The tape mod is real but it dates back to the Core2 Q6600. It allows then to run at 3GHz but performance might not equal the Q9400 you already have.
Here is one running an X5470 Xeon at userbenchmark.com. https://www.userbenchmark.com/UserRun/9028241
The G41 chipset supports that swap. delidded.com has the instructions for that conversion.
https://www.delidded.com/lga-771-to-775-adapter/
That will get you 3.33GHz w/o any overclocking.
