B Bojangle12 Honorable Feb 10, 2014 307 0 10,810 Mar 29, 2014 #1 I have a few 4-pin fan connectors, but only 1 available 4 pin socket, the rest are 3 pin. If i plug in a 4pin fan connector to a 3 pin socket, will the fan still work but just spin at the highest RPMs?
Solution S S spoofer2 Mar 29, 2014 well i know they exist. if you're fine without the pwm control then go for it. otherwise just get the adapter, they're only a few bucks.
S spoofer2 Honorable Mar 19, 2014 254 0 10,810 Mar 29, 2014 #2 you can get an adapter. search 4 pin 3 pin molex adapter Upvote 0 Downvote
B Bojangle12 Honorable Feb 10, 2014 307 0 10,810 Mar 29, 2014 #3 I read some answers on google, they said you can plug it into the 3 pin socket but you lose the PWM ability for variable speed. They didnt say anything about an adapter. Upvote 0 Downvote
S spoofer2 Honorable Mar 19, 2014 254 0 10,810 Mar 29, 2014 Solution #4 well i know they exist. if you're fine without the pwm control then go for it. otherwise just get the adapter, they're only a few bucks. Upvote 0 Downvote Solution
