Can i plug my 4 pin cpu power cable to the 8 pin motherboard
Vana Ivan Pandovski
274
11
18,865
Hi i have decided to by a new motherboard which is AsRock H77M,and i realized that on the pictures that the motherboard have a 8 Pin CPU power connector,here LOOK:
http://i.imgur.com/dm7ywKK.jpg
and i WISH to know from you guys one thing,my PSU hase normal standard 4 pin conetor:
here LOOK:
http://i.imgur.com/0i7SwL7.jpg
so can i plug my 4 pin CPU connector to the 8 pin MOBO conector,is this possible ,or it hase to be a 8 pin,or it can be pluged
with the 4 pin connector on one side left or right ,so i reallyyyyy need this answer .thanks a lot
it considers 2 cpus a i3 and i5 not very highly strong powered cpus...Thanks i need really the answer i pick the solution immidiatley if u help me ...
Howdy.
You should be able to get away with only plugging one 4-pin in and it does not matter which one you use on the board.
You will only need the extra power if you intend to do overclocking.
So technicly i can power up with 4-pin connector from my psu it's not goin to be any porblem ,and no i don't plan to overclock,
first i will trow a i3 -3220 cpu and after i will add the i5 -3570k,so the 8 pin power connectior is ONLY FOR OVERCLOCKING=MORE POWER,right ? Or ?,so is it goin to start is it goin to make me problems on any kind ,i mean the Mobo like not starting or things like that because of a full 8 pin connector,or ?
thanks My point is that ,is it possible to RUN the MOBO with 4 pin spu power connector sience the mobo hase 8 pins,
that was my full teorrry of question is it goin to work properly or it really need to be field with fully 8 pins in there,that was my Q
i wanted to know is the mobo goin to start is cpu goin to have power is everything goin to be ok ??????? with a 4 pin connector
You will be fine with only a 4-pin connector with either of the cpu's you have chosen.
tnx a lot u helped a lot i pick u r answer as solution for this
