I know the wattage is enough, what about the amp requirements? Thank you in advance!
It's a tier4 PSU. Something of higher quality would be much better.
"Tier Four
No Japanese capacitors found. Only Taiwanese capacitors and may even include Chinese capacitors. Very basic safety circuits or even thin gauge wiring used. Not for gaming rigs or overclocking systems of any kind. Avoid unless your budget dictates your choice."
