[SOLVED] Can I power it and does it fit
Sep 7, 2019
5
So I'm buying a new motherboard.
I'm planing on buying Gigabyte z390D, my CPU is I7 9700k, GPU Gigabyte GTX 1070, CPU Cooler: Raijintek Triton, PSU Fortron Raider S 650W Silver, RAM HyperX Fury BlackSeries 16GB 2666 MHz
Yes, your GPU will fit in the new mobo. Unfortunately I know nothing about your power supply, but you should be able to handle everything listed here with a 650w psu.
