Can I power two GPUs with a single dual 8-pin cable?
bran_donger
41
Exactly as the title says. I have an XFX full-modular PSU and two GTX 960 SSCs. The PCI-e cables on the power supply each have two 8-pin headers.
So can I use a single cable to power both cards, or must I use separate cables?
JasonL265
395
If your power supply only has a single cable, then the PSU itself probably isn't meant for SLI and does not supply enough power for two cards. How many watts is your PSU?
I think for GTX 960s SLI you need like 600 Watts, i would go for 750 just to be safe since yours are SSCs.
bran_donger
41
Ah, that's not what I meant. It's an 850W XFX Pro Black Edition, more than enough to power two 960s. There are plenty of PCI-e cables, but I'm just wondering if I can just use one instead of two, for the sake of cable management.
And by using one, I mean it's fully modular, and a single PCI-e cables has TWO 6+2-pin headers, probably meant to power cards with two power inputs. I want to know if I can use ONE of those to power TWO cards.
