You'd have to contact the seller to get that information. Not all of them do. Some manufacturers put AF fans on it because they're typically cheaper than SP fans. I know the majority of the AIOs I've been looking at have AF fans on them. If you're not wanting to drop too much money on the system before you upgrade, an AF fan will do you fine. Just make sure it has screw holes to match the size, and you'll be golden.
