can I put cabinet fan on SPEAKER pins
vk991
44
I want to add two cabinet fans but motherboard has pins for only one so can I use it in pins with SPEAKER written below it,also tell me what is its use it was lying spare..
No, the speaker is for a speaker, not a fan. You can generally get an adapter to lug the fans in to a molex (the one for hard drives/optical drives) or other power connectors. Something like this. but specific to your fan connectors... http://www.newegg.ca/Product/Product.aspx?gclid=CjkKEQjw5qmdBRCn--70gPSo074BEiQAJCe7zWeayUSH_C0CXh5h4LFbqDz8bCpLhljV5HjbNY_HwTnw_wcB&Item=N82E16812311003&nm_mc=KNC-GoogleAdwordsCA&cm_mmc=KNC-GoogleAdwordsCA-_-pla-_-Internal+Power+Cables-_-N82E16812311003&ef_id=Ui9lJgAABXVy-LQZ:20140625154130:s
What is speaker used for then it is not used
The speaker is for use with a speaker, if you don't have a case speaker then there is no use for the connector.
