Question Can I replace a chromebook battery?
axlrose
2,191
15
19,815
I have a chromebook that is in good working condition. It appears the battery died, but everything else is in good shape. Can I buy a replacement battery? Any idea where to trust?
Thanks!
There will be youtube videos on how to change the battery.
Not so hard to do.
"compatible " batteries will cost less than the original.
But, they do not always work properly.
I suggest you buy one of the exact part number.
You may have to buy from the laptop maker to insure no problems.
