Can I replace front Panel USB ports?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
I plan to build a gaming PC with the Corsair 600T mid-tower ATX case. It comes with four USB 2.0 ports and one USB 3.0 port. I would like to replace the USB 2.0 ports with USB 3.0 ports. Can this be done easily or will it void the warranty? Thanks.
Would I be able to use all 4 hubs at 3.0 speed on the device you suggested on either the ASUS Maximus VI Hero or the Gigabyte GA-Z87X-UD4H or GA-Z87X-UD5H?
