can i run 1600mhz ram to 1333mhz max supported mobo?
The problem is my mobo wont recognize 1600mhz ram. Is there any possibilities that it will accept it even in 1333mhz?
Ram can be set at any speed thats in the rams jadec table. So install the ram, go into bios and check to see what the setting is. It should automatically set at 1333MHz (unless the ram is Kingston HyperX, then you are out of luck), if not, then you can manually set it to 1333MHz as the target speed.
