can i run Assassin's creed unity on Gtx 750 1gb graphic card??
but i can run farcry 4 with high settings and whats the difference between 1gb vram and 2gb vram ???
1GB VRAM refers to 1GB of graphics memory and 2GB means 2GB of graphics memory. VRAM has an important role in determining how much textures/ graphics can be rendered by the GPU, provided it is powerful enough.
Far Cry uses a lot less resources than AC:U, they're not comparable. Try running Crysis 3 on your build, and you'll understand the point.
Anyway thanks for the explanation,so I can't run it in my pc 🙁
