Can i run dying light in low settings?
yes you can do it
the major constricting factor is your (dualcore?CPU) and 1gb vram, otherwise you can do medium with playable FPS at 1080p
anyway if you watn to increase the quality ,
reduce the resolution and aa
yes you can do it
