Question Can I run gt 710 on psu 240 my pc parts are amd a4 5300b and ram 6 1600mhz ddr3 hard disk 500g motherboard Hewlett packard 1850 and thanks
bccorrupt
992
16
19,665
200
An OEM 7570 1gb ddr5 card would be a better choice and you can pick them up for about $15-$20 on ebay in SFF and full size. 710 is about 100% faster than your 7480d, but a 7570 is about 100% faster than a 710.
4
You shouldn't have a problem, but there's probably not much point. The GT 710 is more powerful than the Radeon HD 7480D integrated graphics, but both are so weak in performance that the difference doesn't really matter.
I can run some games as Gta 5 or cod black ops and thank you for reply
Jacob 51
Proper
Dec 31, 2020
455
19
185
GTA V will be unplayable. The textures don't load on time, the guns don't appear at all at some points and frame rate is not so good too.
I've used one so I know.
As for COD Black Ops, yes. you can run COD BO 2 too.
On high settings, you'll get smooth gameplay. (720p)
Jul 16, 2021
4
I think you have low cpu bec my friend have same gpu and he can play Gta 5 online 40+ no problem and he can play cod bops 3 and cold War unless he increased the resolution to 800×600 and some can play in 1080
Jacob 51
Proper
Dec 31, 2020
455
19
185
No There is a difference. Does your friend have the GDDR 5 version of the GT 710?
There is a WHOLE LOT of difference between the GDDR5 and the DDR3 in performance.
