Can I SLI an Gigabyte 7950 an Power Color 7870 Myst?
ehyde1029
102
I have a Gigabyte 7950 3gb GPU and a Power Color 7870 2gb Myst Tahiti LE. I read that the 7870 Myst was using some of the same hardware as the 7950. Does this mean they are compatible for SLI?
oooh. However, I wouldn't do it if I was you because it would degrade the 7950 to 7870 level :??: . I would sell one of them and get another one same model 😗
actually you can, but that wouldn't be very smart so you shouldn't, but as you already have both then why not give it a try..
7870 myst uses the same tahiti chip as the 7900 series, thou it has more stuff disabled
edit lol this thread is busy
So since I have both cards right now (The 7870 is going to be RMA'd unless this works) I will give it a try. I have the SLI connector but have never done it before so off to browse the web for some videos on how to set it up
SLI connector, or Crossfire connector? They look similar, but are two different things. SLI connectors are typically packed with motherboards that support SLI; Crossfire connectors, otoh, usually come with graphics cards, although not all include one.
Actually according to Tom's review on the PowerColor 7870LE Myst card found on the home page, you can CF it with a 7950 since it's a Tahiti GPU, the only thing you would need to do is OC the slower card to match the performance of the other.
The performance of an OC'd powercolor 7870 LE (or sapphire's 7870 XT) is on par (sometimes better) with a stock 7950. CF'ing a 7870LE with a 7950 would in effect give you a CF'd 7870LE setup. Before attempting, you should see if your MB is compatible and if your PSU has enough amperage in your 12V rails as the 7870 LE uses more power than a 7950 (200W v ~180W). Including OC, you would need at least a combined 40A along your 12V rail (>600W PSU).
One oc'd is always better than the next better at stock clock, in my knowledge. Anyway, your setup is beast!!
IDK why I keep saying SLI when I mean crossfire. I do have the Crossfire connectors and my mobo (gigabyte TA990FXE) is Crossfire capable. My PSU (Corsair TX650) said it was Xfire ready but after opening my case to plug the other GPU in I noticed my "Xfire ready" PSU only had 2 PCI-E 6 pin connectors. Both the 7950 and the 7870LE require 2-6 pin PCI-E connectors each so it's a no go for now. I guess they didn't lie because some GPUs only take one 6 pin. Getting a new PSU soon so I hope it will work
Just a side note for future buyers the 7870LE is about 2-5 FPS lower than the 7950 in games I've played so far which I could have lived with but the problem I was having with the 7870LE was the temp. They only put 1 small fan on it and in game the GPU temp was 90c on average and would start to lag due to heat. The Gigabyte 7950 Windforce 3 edition was about $40 more but I haven't seen it go above 45-50c so far even in very demanding games
Good to know :)
don't you have molex to 6 pin connector?
I thought the PSU would have come with at least 1 but I got a molex to 4 pin with it? I was having some problems with the 7870LE anyway so it's RMAd. I just played Crysis 3 today and after some sub-par FPS with the 7950 I might have to go to the dark side and get a GTX690 or just wait till AMD puts out their 8xxx series in a few months.
molex to 6pins usually come with the cards, the molex to 4 pin is meant for the mobo atx power connector if your psu doesnt have native one and I would think it was included with the mobo, not with the psu...
and no new gen cards from either camp until the very late 2013.
Never got to try because the card would get to hot and shut down ended up RMA to Newegg. If you get a working 7870LE they have great performance but from what I've read the overheating is a common problem. Thanks for all the help
