can i spray paint corsair liquid cpu cooler?
It's your cooler, you can do anything you want with it. That said, if you cover the cooling fins with paint, you are going to loose a lot of the coolers ability to dissipate heat, kinda making it almost useless.
But it won't hurt the radiator frame or the pump, but you may have problems with the pipes, they are quite flexible and dry paint isn't.
I wouldnt recommend it...
You would have to contact corsair about the warranty, they are usually pretty helpful with any questions such as this.
What specific cooler do you have? You can use red LED fans, and if its an "i" model, you can change the waterblock color.
As long as you don't spray the heat-sink/radiator itself (will adversely effect heat dissipation) There really isn't anything wrong with this.
