As superninja12 said, the only thing that can cause bottleneck is net speed, the bare minimum should be 5-7mbps (not megabytes, megabits) for 720p 30fps
https://help.twitch.tv/customer/portal/articles/1253460
Thats not what I ment😛 you can always stream in lower detail.
I mean an stable connection , like a wired cable from the router to your pc, not a wifi signal unless youre in the same room as the router.
I tried with 3mbps and it worked on bare minimum. Singleplayer work fine.
