Can I take parts from this prebuilt PC and put them in a new one that I will build myself?
grumpymonk123
37
I have a lenovo erazer x315 prebuilt gaming pc and I was wondering if, to make the price cheaper for me, I could take the CPU, hard drive, and optical drive out of it to put in a new PC that I want to build.I know I want to buy a new graphics card, cpu cooler, power supply, mobo, and probably RAM but everything else I want to take from my prebuilt.
Thank you
The reason it's a bad idea is that most of your parts are based on an older platform that does not perform as well as the newer intel options. You can however re-use the optical drive.
n0ns3ns3 stated some good options.
If you give us a budget, I'm sure someone can help work out a build for you.
Here is an awesome build
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($345.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.89 @ OutletPC)
Motherboard: Asus Z170-E ATX LGA1151 Motherboard ($85.99 @ Newegg)
Memory: Crucial Ballistix Sport LT 16GB (2 x 8GB) DDR4-2400 Memory ($49.99 @ Newegg)
Video Card: EVGA GeForce GTX 1070 8GB SC Gaming ACX 3.0 Video Card ($449.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA P2 650W 80+ Platinum Certified Fully-Modular ATX Power Supply ($89.99 @ NCIX US)
Total: $1046.84
Generated by PCPartPicker 2016-07-12 15:57 EDT-0400
If you want, you can save 200$ by going GTX 1060 instead of 1070.
Here is the build with case and GTX 1060
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case ($99.99 @ SuperBiiz)
Other: GTX 1060 ($250.00)
Total: $946.84
Generated by PCPartPicker 2016-07-12 16:08 EDT-0400
Do I really need an i7 processor if its mostly going to be for gaming?
Can't I save even more money if I just an i5?
I know I said my budget is $1000 but I would like to spend the least amount possible.
I would rather get a higher end graphics card than CPU
Short version - you can go i5, but if can comfortably afford i7, you should go that way.
The explanation is simple, oldest game that i'm aware of that takes advantage of i7 over i5 (on the same clock speed) is crysis 3.
More and more modern games rely on multi threading and utilize over 4 threads.
An average gamer (with mid-high end setup) usually upgrades the GPU at least twice as fast as CPU.
So if you go for over 60hz monitor in near future, you going to need an i7 CPU to provide enough data to your GPU.
Going i7, will allow you not to think about CPU for the next 4-5 years (unless there is some revolution).
In this time frame you will upgrade the GPU at least once. The GPU performance you get today for 400$ will be 200$ in a year or so. So it makes sense to go good platform that will allow you just to update the graphics card every now and then to maintain the desired level. It will be also cheaper in long run.
Hope it somehow answers your question.
