Can I trust case-front 1394 connector on chieftech BX
  • Thread starter Thread starter Guest
  • Start date Start date
  • Tags Tags
    DDR
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi all!
I've read some horror-stories about faulty cabling for Firewire ports,
that has destroyed equipment for some people.
Can I trust the front-panel connector on my newly purchased Chieftech BX
case to be wired correctly, or should I use the ASUS-supplied backpanel
bracket instead?
I mean. I don't wanna fry my brand new A8V MoBo the first time I fire it up.
Hoping for a quick correct answer, as I'm sitting here right now with
the PSU powercord in one hand and the extender from the wall outlet in
the other.
TIA /Ola J
In article <_EMqd.9780$d5.88397@newsb.telia.net>, Ola A Johansson
<wheel1@telia.com> wrote:
> Hi all!
> bracket instead?
> the other.
> TIA /Ola J
Use the Asus adapter.
If you own a multimeter, then test the case wiring before using it.
Firewire devices are too expensive to risk on incorrect case wiring.
HTH,
Paul
Hi Paul!
>>Hi all!
>>bracket instead?
>>the other.
>>TIA /Ola J
> HTH,
> Paul
I was too eager to try it out, and I don't have any Fire-Wire devices
here right now, so I just left that unconnnected and started my testrun.
I do own a DMM however, so I guess I'll probe the wires before I connect
anything to either one of them.
Thanks for your tip /Ola J
