[SOLVED] Can I turn a usb printer into Bluetooth?
Tabathavm
I am needing to use the printer from 2 different wifis wanted to know if I plugged a Bluetooth adapter in the back of a printer could I enabled it to be Bluetooth and would this work?
No.
However some routers have USB ports which can then support printers. (only some routers have this, others have USB ports only for hooking up computers or a USB storage drive)
Okay thank you! I guess the best thing I can do is just switch wifi networks when I need to print We have a home wifi and a office wifi. 2 different accounts but use the same printer.
Using a USB wifi print server may do this, if the printer has built-in Wifi, you can configure the print server on the other network. Something like a Linksys WPS54G, you can find them used in places. You can also wire the printer to a computer and then share the printer out to others on the same network.
