Can I uninstall Corsair Link and keep my settings?
faysal32159
144
I think corsair link is causing problems on my computer and I want to uninstall it but was curious if I would still have a fan curve I set for my fans if I uninstall it.
Hey Zeroplanetz, Yes, you can actually save the LED color that you want then move the cooler to a different system that doesn't have Corsair Link and keep the color that you saved last.
What kind of issue are you having with Corsair Link? utroz is correct, the moment you remove Corsair Link from your system, the fan curve you created goes with it. You'll be able to retain the LED color on the pump, but not the fan curve. You can set them on fixed rpm and will stay that way even after uninstalling link.
Ah sorry for the bump, figured id ask without creating a new thread. Can I set the pump color to what I want and then remove it from PC and put into a hackintosh and retain the pump color? I need a orange led and would like a 120/140 rad size for an aio unit. Thanks any and all for the help!
P.s the PC is mine, the hackintosh is for the lady. And its an orange theme in a prodigy m case.
