[SOLVED] Can I use 2 wifi range extenders at the same time in my wifi network?
Eikonikos Eikon
69
Hi, I have 2 wifi range extenders. The first model is tpLink TL-WA850RE and the second model is TP-LINK TL-WA854RE. Can I use both these two wifi range extenders on the same wifi network?
Should I put differnent ssid to each extender or the same ssid with router?
You can use as many extenders as you like. I like to use the same SSID, but you can go either way. Might be helpful to use different SSIDs at first so you can get a better idea of where you have a good signal and where you don't.
