Can I use 2 x 3 pin fans on a 4 pin Y splitter?
flamegunners
Currently, Im using a ASUS B350 Prime Plus Motherboard in a NZXT S340 Elite Case.
The case comes with 2x 3pin fans (one rear, one top), connected via a splitter to a female molex.
Since I will be using the single molex (peripheral) port on my EVGA SuperNova 650W G3 PSU for my led strips, I would like to connect this 2 x 3 pin fans to a 4 pin header on my motherboard instead via a 4 pin splitter ( 1 to 2 ). My question is , is this safe to do so ? Will the power draw be too overkill for my motherboard to handle? Thanks in advance.
Illustration:
----------[ 4 pin header ]-------------
--[4 pin]--------------------[4 pin]--
--[3 pin]--------------------[3 pin]---
No problem. You can run two cases fans off of one mobo case fan header. Most fan headers will supply 1.0A. Case fans generally max out at 0.3 to 0.4A. Thus, 2 fans are fine and 3 fans can be iffy. Also, the 4 pin Y splitter is fine. The 4 pin splitter can be used with your two 3 pin fans. You just don't want to mix a 4 pin fan and a 3 pin fan on the same header.
