can i use 5100 Mah battery instead of 4680 Mah battery ..will it be ok to fix in the laptop
my model is mac book a1406 battery and default it has 4680 Mah
thanks for the replyIf it fits and has the same charging and output current and voltage then yes. Just make sure it isn't some cheap Chinese knockoff wouldn't want to set your house on fire
thanks for the replyYes, as long as voltage output is the same and it will physically fit then all it will do is give you a longer battery life.
