Can I use a 120mm fan as a rear exhaust fan?
I don't doubt your measurements but the hole spacing is not enough for a 120 on the rear of that case so a 120 will not fit. IF you have the measurements of a 92mm and a 90mm then that could be a great help to the OP?
if the measurement between the holes is 4 1/4 center to center across a 120mm would bolt in.http://www.newegg.com/Product/Product.aspx?Item=N82E16811147122&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Computer+Cases-_-N82E16811147122&gclid=CjwKEAiA9KymBRD6g6iOvv2joU0SJAB0vRQyzPL1yX9cQDeXtlQo_Lzzx30fqONuzlI1lPDtG9H6lxoCQqTw_wcB&gclsrc=aw.ds
