H Harley_2 Reputable Feb 13, 2016 1 0 4,510 Feb 13, 2016 #1 im wondering whether a 120mm fan case fit into a 140mm slot Here are my case specs http://store.antec.com/gaming-series/three-hundred-two.html#
Solution DonkeyOatie Feb 13, 2016 Not in that case. It needs 120mm mounting holes. You could buy or make an adaptor bracket. http://www.amazon.com/Bgears-Cooling-Fan-Adapter-140mm-Black/dp/B0043GMY1U
M Mr Hat Reputable Nov 30, 2015 301 0 4,860 Feb 13, 2016 #2 Harley_2 : im wondering whether a 120mm fan case fit into a 140mm slot Here are my case specs http://store.antec.com/gaming-series/three-hundred-two.html# In what slot would you like to put it, on top? Front? Bottom? If you decided, check the website you linked, it's under "Specs". Upvote 0 Downvote
DonkeyOatie Champion Sep 16, 2014 12,141 1 50,960 Feb 13, 2016 Solution #3 Not in that case. It needs 120mm mounting holes. You could buy or make an adaptor bracket. http://www.amazon.com/Bgears-Cooling-Fan-Adapter-140mm-Black/dp/B0043GMY1U Upvote 0 Downvote Solution
