D
Deleted member 2004685
Guest
I have a z170-a motherboard and a gtx 1060, the 1060 has 6 pins in it, and the power supply is 8 for it, can i just the 8 on both sides cord and plug the 8 ping into the gpu? its a 2x3 in the gpu (the power cord thing is 2x3, then it has two other connecters to make it 8 that just arent connect but are connected by wires)
Just wondering if i can put this: in my gpu
https://www.google.com/search?q=8+pin+cord&espv=2&biw=1920&bih=974&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjGuszdr9bQAhVmwYMKHQ12AbMQ_AUIBygC#tbm=isch&q=8+pin+cord+gpu&imgrc=MJOEApR3B1MmtM%3A
