Ray-Ray60 Honorable Dec 14, 2012 1 0 10,510 Dec 14, 2012 #1 I'm wondering if I can use a 12 volt battery charger ( just for testing ) I have a timer that the input voltage is 12 vdc and the output is also going to be 12 vdc I just want to test the timer before I install it on the end device?
ex_bubblehead Titan Moderator Aug 24, 2012 17,815 2,282 89,240 Dec 26, 2012 #2 As long as the load doesn't cause the charger to exceed its current limit it should work just fine. Upvote 0 Downvote
