N Not one of you Reputable Jul 22, 2014 2 0 4,510 Jul 22, 2014 #1 I lost my power supply when I was moving and I need a new one what should I do?
Solution P P Pondering Jul 22, 2014 They sell replacement power cables at tech stores. The in-store price is around $10. "6' AC Power Cable" Example: http://www.staples.com/Belkin-6-Pro-Series-AC-Power-Cable/product_657015
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Jul 22, 2014 #2 You mean you lost the cable? If so thats fine. Almost all PSUs use identical 3 pin cables. My main monitor uses the same cable, as do my 2 others PSUS, 3 other desktops, and 2 old monitors. Upvote 0 Downvote
P Pondering Honorable Dec 7, 2013 1,023 0 11,660 Jul 22, 2014 Solution #3 They sell replacement power cables at tech stores. The in-store price is around $10. "6' AC Power Cable" Example: http://www.staples.com/Belkin-6-Pro-Series-AC-Power-Cable/product_657015 Upvote 0 Downvote Solution
N Not one of you Reputable Jul 22, 2014 2 0 4,510 Jul 22, 2014 #4 Thanks for the help! You guys are amazing! Upvote 0 Downvote
