🤔 You sure you don't have that backward?
32 inch 4K Monitor
LG 32UL500-W 32 Inch UHD (3840 x 2160) VA Display $330
32 4K TV's are kinda rare and expensive because the size is less desirable, the cheapest you will find will probably be around $430. A 43 inch TCL 43S425 4K's Starts at $229 because that is generally the lowest screen size most panel makers will target on 4K.
The difference between a monitor and TV?
TV
More connection options
Tuner or Smart
Speakers 4W+
Can be tuned for gaming response but not always.
Designed for the user to be 6 feet + for preferred viewing, maybe too bright if you're closer than that.
May seem blurring and grainy up close even at 4K
Stands are not adjustable.. just a pair of feet
Monitor
Limited connections options
No tuner
Might have speakers but they are 1-2W max and not very loud
Designed for either gaming "Fast response" or editing "Better color scale and clarity"
Designed for the user to be 3-4 feet optimally, maybe less bright beyond that.
Stands typically are adjustable for tilt and height.
