Can I Use a Sata I Power Cable
waffleisback
Commendable
Feb 13, 2017
158
I am planning on building a cool little system inside of an older HP Pavilion Slimline Case and have to upgrade the power supply to handle my new graphics card. I noticed that on the power supply post on newegg it says it has a sata 1 connector. I was wondering if I could use this to power my ADATA SP900 256GB SSD.
Thanks in advanced.
( by the way this will be my first computer i have built )
Links :
Power Supply : https://www.newegg.com/Product/Product.aspx?Item=9SIA5751VA7562&cm_re=s3713w_power_supply-_-9SIA5751VA7562-_-Product
Pcpartpicker list : https://pcpartpicker.com/list/DxwGHN
Yes, it looks like a normal SATA flat style power connector.
I cant tell if the GFX 1050 card requires a separate 4 pin power connector or runs totally off of the mobo power as its 75w TPD , but your psu page states "4 Pin Peripheral" which might be it.
Thanks! 😀
I looked into the graphics card and I think it gets all of its power from the motherboard.
