[SOLVED] Can i use a sata power to 8 pin to power up my gtx 1660S?
Apr 5, 2020
11
Im missing some of the cables of my seasonic M12II 520 psu. Do i have other means to power up my gtx 1660S?
Im using all of the modular cables and the ones i didnt use but need now, i may have misplaced... F***.
NEVER use a SATA-to-PCIe adapter or molex-to-PCIe adapter. (EDIT: this puts you at high risk of the "magic smoke" mentioned in the other thread)
The M12II is supposed to come with 2 of the 6+2 connectors. If you are missing the modular cable, see if you can get it from Seasonic.
