Question Can I use any 8 pin connector to power my Motherboard?
GilaStomper
243
I'm transplanting my old Dell Optiplex 9020 from its old case to a new one. Along with this I have a bought a new power supply.
That being said I have noticed my Dell's motherboard only has an 8 pin power slot and 4 pin power slot instead of the 24/8 pin slots I've had on previous builds.
Can I use any of the 8/4 pin connectors to power the motherboard or do I HAVE to convert my PSU's 24 pin connector to make it work?
I do know my PSU comes with an 8 pin connector.
No. You need an adapter cable. Watch this video --
View: https://www.youtube.com/watch?v=YXkRa6xM0oE
the link has a picture of the various connections. looks like #11 is some type of power along with #1 and 7.
you can't assume this is the same 8-pin from the psu. it may well be, but until you can prove it, it is not a good idea to asume. this is part of the reason we don't like recommending pre-built systems. they do stuff like this making it impossible to upgrade in many ways. these connections are rarely standard ones we see on normal consumer psu's. since the psu is made for the specific system, they can change all the standard stuff and do whatever they feel like. so again. there is no guarantee those are standard connections from the psu. and i have no idea what that #11 connection is at all.
watch that video, looks like it has some answers in it. or kanewolf would not have posted it :)
he knows what he doing!!
Okay confession time, this is my mates PC and I told him not to buy a Dell optiplex and turn it into a gaming PC. Well were here now and I kinda owe him one.
What is connection #11? That looks too small to be a power pin, yet i have never seen something like it on a build.
all it says is "HDD/ODD power connector "
not seen it before either so no clue.
you might be able to find a new mobo for that but as it's intel 4th gen, it may be expensive since they are long out of production
I've asked my mate and it seems like I can just remove the currently cable in that slot and use it the same way in the new build. No need to buy special adapters for it :)
All you need is the 8 pin and the 4 pin in order for the board to be powered. You will need a 24-8 pin adapter cable.
HOWEVER you cannot easily move that motherboard to another case. It is matx and will fit, however all of the front panel connections are proprietary, meaning you wont be able to plug in front panel audio or USB, and you will get an error on boot. You can fix this with a lot of soldering and custom adapter cables, but it just isn't worth it.
I did this exact same thing and ended up with a working PC using a matx case and standard EVGA psu in with the sff board, but it literally took me hours upon hours to make the front io work.
https://ibb.co/QkcX65H
What do you mean it will not boot? I can understand the front USB stuff not fitting in but from what I've seen online whats stopping me from plugging in the power thing?
View: https://youtu.be/gEhBWZD9CDw?t=762
I never said it would not boot.
It will however give you an error on boot. You just have to press F1 to dismiss it.
Do you have the MT, DT, or USFF version of the 9020?
It's this one
NGL It's the cases power pins that have me worried ATM. I have no idea what goes where with the power pins after reading the manual for it all.
Edit: The board it uses is this one
