Question Can I use auxiliary cpu fan socket for 4 pin pwm fan?
RenTheReaper
Great
Mar 29, 2022
170
GTX 1660Ti
i5 9400f
Windows 11 Home (in progress)
Raidmax P805
Asrock B365M Pro4
Hello. I have a B365M Pro4 motherboard. I wondered if its possible to connect one of my 4 pin PWM fans to my auxiliary CPU air/watercooling fan (CPU_FAN2/WP) especially seeing as I am not going to be using water cooling or a second CPU?
I have a PWM fan splitter cable but I've heard that it might cause both fans to be able to draw less energy if they need it.
The fans I am using in question are Coolermaster Sickleflow 120mm fans.
