Don't, it's very aggressive solvent.Can I use brake cleaner to remove thermal paste from AM4 CPU socket?
Chlorinated? or the non-chlorinated type?Can I use brake cleaner to remove thermal paste from AM4 CPU socket?
LOLwhatever works with cleaning cpu sockets
is it a big deal if I get a little bit of thermal paste on the socket and would that introduce random freezes and slowdownsBrake cleaner even dissolves plastic screwdriver handles, and the AM4 socket is plastic. The proper product is a plastic safe spray electronic cleaner or electrical contact cleaner. If you must use something from the autoparts store then MAF sensor cleaner is probably closest.
You'd have to use a LOT of it to get paste to run out of a closed socket like AM4 and off the board. At least that socket design makes it really hard to snag any pins.
Yes if it insulates one or more pins.is it a big deal if I get a little bit of thermal paste on the socket and would that introduce random freezes and slowdowns
