Caesar-_- Reputable Aug 20, 2019 67 0 4,540 Apr 15, 2020 #1 can i use duel channle with 1x16 and 1x8 they are both the same, same cl same hertz crucial ballistix lt sport red they are both 2400mhz cl16 the board is Gigabyte H310s2h
Solution Math Geek Apr 15, 2020 no you can't has to be same size and speeds to use dual channel easy peasy.....
Math Geek Titan Ambassador Oct 15, 2014 18,026 2,337 101,590 Apr 15, 2020 Solution #2 no you can't has to be same size and speeds to use dual channel easy peasy..... Upvote 0 Downvote Solution
S SamirD Judicious Jan 16, 2014 6,610 956 35,940 Apr 16, 2020 #3 Since this is DDR4, no way. You should also look for a set to guarantee success. Upvote 0 Downvote
