[SOLVED] Can i use M.2 + PCI with my motherboard asrock zzz7 pro 3?
Oct 1, 2021
13
Hi im tired of my slow HDD bit i Heard my motherbase cant use M.2 but i Heard i can with adaptador PCI, is that possible? Will i have problems? Should i just buy a SSD instead? Is for games
Please list them like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Include the make and model of the M.2 SSD that you're looking at.
Edit:
noticed you were referring to the ASRock Z77 Pro 3. In which case, you should look into a cheap 2.5" SSD to breath life into your build. I'd advise against using an adapter to drop an M.2 SSD in that build. Even if you did get it to work, you'd loose out on the M.2's potential.
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Edit:
ASRock Z77 Pro3 66.12 1 66.12
Corsair GS800 V2 800W Gaming Series 78.51 1 78.51
G.Skill Ripjaws X DDR3 2133 PC3-17000 8GB 2x4GB CL9 61.12 1 61.12
Intel Core i5-3570K 3.4Ghz Box 158.68 1 158.68
LG GH24NSB0 Grabadora DVD 24x Negra 13.18 1 13.1
Rx 570
Scythe Mugen 4 33.02 1 33.02
Seagate Barracuda 7200.14 1TB SATA3 44.59 1 44.59
Win10
Ok thanks!!
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Edit:
One of the first Two of this list are ok? Or should i buy another one like a Samsung?
https://www.amazon.es/gp/bestsellers/computers/937918031/ref=zg_b_bs_937918031_1
