Question Can I Use Mi LED Smart TV 4X as a Gaming Monitor in 4K?
gjvphvnp
Commendable
Nov 5, 2017
20
Hello, I need to know whether I can use the monitor TV mentioned below can be used as a gaming monitor in 4k at 60 fps?
I am using RTX 2080 and will use hdmi port to connect these two. Will it be able to handle the games well in 4k or 2k in 60 fps. Also the response time is 6.5ms and refresh rate is 60 hz. Will I encounter any problems?
TV : https://www.mi.com/in/mi-tv-4x-43/
Spaceghaze
Proper
Oct 17, 2019
105
8
115
6
You should be able as long as it has HDMI 2.0.
Rest depends on what games you will be playing. FPS games might be bothersome to play with that respons time.
