[SOLVED] Can I use multi-purpose spray when cleaning my GPU?
barkersofgeraldine
151
7
4,585
I watched a video of Yes Tech City, and this dude loves spraying tap water and "multi-purpose" spray on his GPUs
Does anyone know of what brands I can use? YTC is from Australia, and has warned that the brand he uses is not available in the US, so people need to be cautious of what 'type' and brand of multi-purpose spray to use
The only 'multi-purpose' spray I can find is ones for cars, and I don't think they're what I'm supposed to use; can anyone recommend me any brands?
Alternatively, what else can I use to clean my GPU? (pcb, fans, and all)... just pure isoprofyl?
Are you just trying to get rid of dust? If so it'd be best to just get an air duster if you have an air cooled GPU. No need to get a multi purpose spray. Also a non-abrasive cloth if you want to physically touch any components on the PCB itself. For the PCB if you really want to liquid clean it distilled water also works fine. Just make sure everything dries before putting it back together.
Reactions: barkersofgeraldine
