can i use mutipal parts of pc
Some motherboards will support dual CPUs. It will ONLY work with Xeons or AMD server CPUs. Normal desktop CPUs will not work. Dual graphics cards can be used in either a cooperative manner (SLI for example) or as discrete devices. Dual power supplies are used on servers. There are ways to use multiple power supplies on a desktop configuration but that is the exception rather than the rule.
What problem are you trying to solve?
The short answer is no.
The long answer is that only server motherboards will have sockets for multiple CPU’s. You can use two graphics cards at once if they are the same card but it is usually better to get one more powerful card vs two weaker ones. You can use two power supplies but you would have to custom wire them in. Then wire them in a way that both receive a signal to turn on with the PC.
