Can I use my old wireless router as a wireless bridge?
fpdave
5
I have a wireless setup at home with a netgear wireless ADSL router connected to my ADSL, and my main pc wired in to it upstairs.
However, I also want to have a small network downstairs and cant/dont want to run wires. I have my old(er) Linksys WAG354G ADSL router and was wondering if there is any way to set it up bridge between 2 wired sub-networks?
I know its possible to purchase special wireless bridghe devices, but I dont want to spend £45 if I dont need to, and my linksys router is unemployed at the moment ;-)
You can check for dd-wrt firmware (http://www.dd-wrt.com/dd-wrtv2/index.php) for your router that allows it to be put into bridge mode.
Grumpy
I think it doesnt support the WAG354G.
ARe you saying that with the standard firmware its simply not possible?
I don't know if it is or isn't. I'm not familiar with a WAG354G. Go to the Linksys Support site and check.
Grumpy
did you find any solution?
i have also one wag354 that i want to use as a wireless bridge!
please send me reply to
sculper @ gmail.com (without the space)
thank you in advance!
