S Semune Honorable May 21, 2012 12 0 10,510 Dec 1, 2015 #1 Can I take my PC, connect it to my TV via HDMI, then have it work without setting it up via my monitor? I just bought a PC but I won't get the monitor until later (shipping), but I want to check out the PC without the monitor. Thanks for any help.
Solution Mankar Kameran Dec 1, 2015 Yes that will work. If it doesn't show up then try switching inputs. It should be listed as HDMI 1 or something close to that.
Mankar Kameran Honorable Jul 13, 2015 488 0 10,960 Dec 1, 2015 Solution #2 Yes that will work. If it doesn't show up then try switching inputs. It should be listed as HDMI 1 or something close to that. Upvote 0 Downvote Solution
terry4536 Glorious Mar 28, 2010 9,741 6 46,265 Dec 1, 2015 #3 Yes, just plug the HDMI into the TV (plug the other end to the HDMI output of your graphics card ) and select that source with your remote. Upvote 0 Downvote
