can i use my viera led tv as pc monitor?
amrit007
15
my graphics card have two dvi ports and a mini hdmi port........my viera (TH-L24XM6D) tv has two hdmi ports and usb ports...so if i use mini hdmi to hdmi cable can i use it as pc monitor .....i cant find any pc mode in my tv :-( ..help please urgent
sami5
104
cant you just try it? its not like it will blowup or something.
anyway i think all you have to do is plugin the TV and go to screen resolution and detect the other display and it will magically work.
Outlander_04
BANNED
Nov 18, 2008
20,311
2,089
Just plug it in HDMI to HDMI
Take note of the Hz rating of the screen . And set your graphics output to the same
Or just enable vsync on your graphics driver if you have any screen tearing issues
amrit007
15
thanks but if it doesn't work then how could i i change resolution or something ..... i am not not able to view anything right ? ....because my old monitor only have a vga port which is again not exist in my new graphics card :-(
Outlander_04
BANNED
Nov 18, 2008
20,311
2,089
Plug it in and find out
I think you will find they put an HMDI port on the graphics card so it can be connected to an HDMI port on a monitor or tv
Use the TV remote to select the correct HDMI port as the source
sami5
104
it will work
Similar threads
