Hi guys,
I recently bought a new PC case (Fractal Design Define 7) which comes with a fan hub (Nexus+ 2) to which I can connect multiple 4-pin (PWM) as well as 3-pin fans.
I have a Noctua CPU cooler with 2 x 4-pin fans, but my case has only 3 x 3-pin fans installed.
I am wondering now if it makes more sense to either
(i) Connect ALL fans (CPU + case fans) to the fan hub and then connect the hub to the CPU_FAN port on the motherboard, or
(ii) Connect the CPU fans directly to the CPU_FAN ports on the motherboard, and connect the case fans to the hub and then the hub to a CHA_FAN port on the motherboard.
I am currently using option (i) as this is how the case manufacturer recommends it and it seems to work fine.
However, I read in other threads that it is usually more recommended to split CPU and case fans to control them separately.
Is this true, so is option (ii) really preferred?
If so, can I even do this with my setup? Since I only have 3-pin case fans, I am not sure if the fan hub would even work without one of the 4-pin CPU fans connected to it.
Unfortunately, this does not become clear from the user manual (although the user manual says that the first connected 4-pin fan is the one that reports RPM to the mainboard, so this is probably a hint that it would NOT work without at least one connected PWM fan...).
If anybody knows the Fractal Define 7 case and/or this fan hub and could give some advice here it would really be appreciated.
