Hi, would I be able to clean old thermal compound off my laptop's cpu and gpu using Pledge Electronic Cleaning Spray made by Johnson? I am sure it contains Methylisothiazolinone.
I wouldn't. I know the stuff you're talking about, even those electronic safe dust sprays are a tad greasy. They do well for the outside of a pc case or wiping off dvd players and stuff but not good for the cpu. Alcohol is safe, non caustic, evaporates and leaves no residue behind which makes it perfect (plus it's cheap, so bonus).
Hi, thanks for the replies! I just want to make sure that this would be okay CLASSIKOOL 70% PURE ISOPROPYL RUBBING ALCOHOL + 30% PURE DISTILLED WATER? Thanks
The alcohol is the active solvent that removes the thermal compound. The distilled water just dilutes the solution.
Oh okay! would I be able to use cotton buds to take off the old thermal compound as I have no lint free cloth or coffee filters?
Cotton balls should be okay. I use paper towel dipped in the solvent to do my cleaning of the TIM. Just make sure no cotton or paper fibers are left on the CPU heat spreader and/or heatsink's contact surface.
